Review of a locker with a M6
I initially thought there was something wrong with it till I came on here and read this is just the nature of having a locker from what I am about to describe.
Now most of the driving I have always loved to do is go find some curvy roads. I would not feel safe with this type of driving as around corners and shifting would not be predictable at all. So that is out. I am half tempted to put a Posi in the car come spring just to be able to get back to this type of driving.
While launching the car though. The feeling is bar none. While shifting at WOT I can only compare it to feeling like a automatic transmission if your shift is quick enough. It will stay locked and you dont have to worry about the car swaying side to side durning a shift.
In parking lots or twisty roads you just need to feel what what gear the car needs. For example in a left turn lane I start in second so I am not over revving the **** out of the motor and there isnt enough power going to the rear to lock up the wheels and basically have a spool. If you even tap the gas it will be locking up and be ready to start to slide if you keep in it. For Daily driving I noticed that I can not shift like I normally do , You either shift fast every time or, hold it in neutral for a second to let the transmission sync up again. This goes back to learning how to drive the car again. Durning your shift you will lock and unlock which makes the car sway side to side. My car has generally pulled to the left a little bit. I am not sure if thats just the general with every car or a suspension issue.
The little joist is what you need to be ready for on long sweeping corners. Like on ramps , long rodes if you are shifting. Say on a un ramp a lazy 2-3 shift will catch you off guard if in the rain. I intially put the locker in with 315 bfg dr's and I think they softened the blow alot more. I now have a narrow small sidewall highway wheel in 18' and there isnt that sidewall there to go with the locker.
Parrel Parking and U turns Parking is not bad It clunks alot harder just from how tight your turns are. U turns Unless you are on a 4 lane road are not happening unless you just wipe the *** end around. If you begin to take a corner to sharp and to fast you will know. You can feel it through out the car. This is how you know. It feels like the car is about to fall apart. As I am guessing there is no slip like in a automatic transmission
In conclusion. If your car is a Daily. Look else where. If your car is a canyon carver. Look else where. If your going to be embarrassed by everyone staring at you in the gas station cause something sounds wrong with the car aside from that one guy who knows your car is some **** not to be messed with. Well I think you get the point.
I am not disappointed at the least with mine. I can say I was not ready and I bought it with out doing and research only after it was in my car I learned all these issues were normal. I like the fact I can throw whatever at it and not have a damn thing to worry about. I drove it daily for about 2 months in traffic and got used to it like it wasnt even there.
Here is why I upgraded to a locker. This was a Ford Track lock and a Cast case. On 370rwhp twin disk clutch , 4 inch drive shaft and 315 dr A locker and a Nodular case ensures me this will never happen again
http://www.youtube.com/watch?v=vHHXJlQGFvY
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
My locker has never made that many clunks in a corner. It usually locks up about half way through the turn and starts to make the tires chirp like a spool. But I bet it is becuase I have a auto...
Ive been seriously thinking about going with a Manual Valve Body Th350 but I just got 22 Mpg on a 800 mile trip last weekend and I dont know that I want to loose that. And at the same time I dont want go back into the rear and pull the locker to make the car fun for me again.
I can see a locker being perfect imho for the weekend racer with slicks and skinnys. Or for someone with a automatic like said above.
I got my unit out of a nascar setup from Tripp Motor Sports. It was a Nodular Unit 3.82 gears Rem polished. 1350 yoke . And the Daytona Support for around 800 shipped. And the kicker was it was from a nascar team which makes my car like 33% race car now lol Click here for where I got my unit. I highly recommend them.
That up there with trying to expain why your wheels studs stick out.
https://www.brutespeed.com/rear_end_information.htm Info on Wavetrac can be found here. Bob
http://shop.brutespeed.com/Moser-9-I...h-Wavetrac.htm
wouldnt trade it
