U-joint question.
Old Jul 31, 2010 | 07:53 AM
87LX5.SLOW's Avatar
Default U-joint question.
Ok my car is a 92 model with a stock rearend for right now, the driveshaft is a chromoly nitrous shaft out of a 4th gen with a 12 bolt. I believe it to be a 1330 style joint on the shaft and the yolk on the rearend to be 1350 if I recall correctly. A few years back on a different car (3rd gen with 4th gen shaft also) I made one joint out of two joints and made one to work for this same issue im having now but I cannot recall part numbers or anything else. Anyone possible know which two I need to purchase to make the one I need? As I stated before the shaft has 1330 and yolk is 1350. Any help would be great as I have searched a little and have only found one I would have to order and I really would like to get this done today.
Old Jul 31, 2010 | 10:05 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
if your numbers are correct- 1330 to 1350- it is a Neapco 2-3050
Old Jul 31, 2010 | 10:18 AM
87LX5.SLOW's Avatar
Thanks alot, I'll be going pick up one here in a little while!
