Rearend
Old Jan 15, 2011 | 03:17 PM
racerrit's Avatar
Default Rearend
Ive got stock 7.5 welded axle tubes mosier axles and 3.73s. Just wondering if the 2002 ws6 pos unit will hold at all or if i should break down and buy eaton now instead of later. And how well do they pull pos
Old Jan 17, 2011 | 10:48 PM
01ssreda4's Avatar
In my experience, I have never seen a broken set of gears or axles in a 10 bolt. Only thing I have ever seen is a broken posi and bolts backing out of the torsens causing the bolt to roll around and get chewed up.
Old Jan 18, 2011 | 05:46 PM
racerrit's Avatar
Thanks for ur input
Old Jan 18, 2011 | 08:20 PM
xtreme2001's Avatar
i have broken gears,snapped axles and even destroyed the carriers.........i have welded up the gears in my carrier(torsen) because i stripped out the gears in it......so far it's holding up
