Carrier question
Old Feb 3, 2011 | 12:37 PM
Gm_Ls1's Avatar
Default Carrier question
So my carrier and gears got messed up. I was wondering if i could put either a 2 serier or a 3 seriers carrier in my rear end since im getting a new one. Or do i have to keep the same series as my old carrier.?
Old Feb 3, 2011 | 01:02 PM
LiT1_up's Avatar
You can go back with either one in that housing as long as you use the proper gears.
Old Feb 3, 2011 | 01:12 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^correct. With a 2series carrier,you can use 2.73.3.08,3.23,3.42,3.73.4.10(3.23 thru 4.10 have to be the 'thick' gearset). With a 3 series carrier,you can use 3.23.3.42,3.73,3.90,4.10.4.56.
Old Feb 3, 2011 | 01:35 PM
Gm_Ls1's Avatar
thanks for the fast reply guys..
