9" w/spool popping while moving
this rear end has a strange case, strange pro lightened spool, moser 35 spline axles 4.11 street gears.
while moving, it will randomly pop very loudly. its not just a noise. u can see the wheel jerk, even in a straight line. it gets worse while turning. we pulled the axles and the 3rd member out and cant find anything broken. there wer alot of very fine metal flakes in the oil but no big chunks. the splines on the axles look fine, still have the machining lines on them. there is a very slight wear mark ring right where the splines in the spool on the driver side start. we slid the matching axle into the spool on a bench and they both have the same amount of play (should there be any?) all the bearings are tight, no play. this rear has maybe 100 miles on it. any ideas?
During a turn the outside wheel has to spin faster than the inside wheel, and the spool won't let that happen. So the car has to actually drag one tire around while turning. This is rough on the driveline and the tires.
The popping noise you hear is probably the axles unloading from the tension built up when one wheel is trying to turn faster than the other.
as for the metal, we figure with as few miles as this thing has on it, it isnt done breaking in yet.
ill let yall know if this fixes it
