realtime gear data
Old Feb 10, 2011 | 11:18 AM
straightleg's Avatar
Default realtime gear data
this is a rearend gear question
its almost time to purchase my new fab 9
you guys running 350's, 383's, 406's motors with a4 trans and NO POWER ADDERS
what is your 1/4 mile trap rpm
please list you setup tire hieght, stall, rear GEAR, what gear your in when crossing 3rd or 4th.
I'm triing to decide wether I can run a 4.30 gear.
from what it looks like on my AFR monitor I'm trapping at 5600 rpm with 3.73 gears in third with 3000 stall @ 12.25/108mph with a 355 sbc, 27" tires
the car is 90% strip 10% street and when it sees the street never more then 55mph fuel is not a concern.
rpm calculator claims going to a 4.30 I would only go through 6000rpm. This sounds low to me.
some real numbers would be great to see.
thanks
Old Feb 10, 2011 | 11:41 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
where does the engine peak at? what's the rpm you'd like to be at? Most 23* head sbc's will want to turn 6500-7000 rpm, but without knowing where you need to be then gears are hard to calculate. heres a link to alot of calculators that should help you decide. http://www.wallaceracing.com/Calculators.htm
Old Feb 10, 2011 | 01:34 PM
I believe it peaked at around 5800 when I had it on the dyno last. the cam claims 6200. I have shifted on accident at 6800 and 7000.
in a couple years I'm hoping to build a 383 or 427 sbc the will run 6500 to 7000
I'm just wondering if my 350 is going to be reving through the roof at the 1/8 mile not going anywhere and my et drops to 13's
I can change the cam to suit but the bottom end is still a stock 010 block
