Is it worth it swapping to a performance driveshaft?
Old Feb 15, 2011 | 08:22 PM
Greekey's Avatar
Default Is it worth it swapping to a performance driveshaft?
Guy is it worth it when your still on a good ole' stock 10 bolt? I think my u-joints are on their way out. I've also just finished a head and cam swap, so I dont think this 10 bolt will last to much longer if I abuse it. If I get a 9 inch rearend later down the road wont I need a different driveshaft?
Old Feb 15, 2011 | 09:02 PM
TransWS6Am's Avatar
my drive shaft broke before my 10 bolt broke. The drive shaft took out all kinds of things when it twisted in half, to include my transmission tail housing, my slp y-pipe, and my torque arm. Not to mention the 2 or 3 holes it put in my floor board. If your not going to upgrade atleast get a safety loop if you don't already have one, it may save you alot of money in the long run. You can run a stock length drive shaft with a 9", its only going to be about 3/4" to short.
Old Feb 15, 2011 | 09:41 PM
Greekey's Avatar
What shaft are you running?
Old Feb 15, 2011 | 09:46 PM
TransWS6Am's Avatar
This one.http://www.ws6project.com/user_stor/...oducts_id=1648 I'v had it for about 3 years. I just ordered my MWC fab 9" yesterday, im going to see how that stock length shaft works before i decide if im going to order one 3/4" longer.
