Strange 12bolt help
I am trying to pull the axles so I can remove the wheel studs in order to put the 3in long wheel studs.
My problem or question is how the hell do you get a wrench on the 4 bolts that hold them in? My axles have the abs or traction control ring on them but I am going to remove them also. That is why I need to pull the axles also. Please help and thanks
Or call them in the morning 847-663-1701, they'll help you.
I figured I'd post this before you were inundated with all of the "you should sell it and get a 9" rear" comments.
