Pinion Bearings
Old Mar 15, 2011 | 12:53 AM
Gm_Ls1's Avatar
Default Pinion Bearings
Im a little confused between these two parts. Are they both concider Pinion bearings.
and
Old Mar 15, 2011 | 12:59 AM
Big Al's Avatar
The lower picture shows the carrier bearings, crush sleeve and pinion bearings. Also has the gasket sealer, thread sealer, marking paste for setting the ring and pinion and some shims. It's a complete installation kit.
The pinion has a large and small bearing, both tapered roller bearings.
Al
Old Mar 15, 2011 | 01:06 AM
Gm_Ls1's Avatar
Al
Got it thanks.
Old Mar 15, 2011 | 10:09 AM
SS SLP2's Avatar
Al
I agree with Big AL
OP if your question is to the first picture that is the race and cone,( may be called the roller) when mated together they become the "bearing"
the race is pressed into the housing (pinion support), cone/roller is pressed onto the pinion
OP if I misunderstand your question, I beg to be overlooked
Johnny
