4.10 4.56
Old Mar 17, 2011 | 07:20 PM
Brando5641's Avatar
Default 4.10 4.56
What gear/rpm are you at with each?
i have 3.42's and they are killing me at the track. i am hitting the rev limiter in 3rd about 50' before the line.
also are all the 10 bolts 7.5'' ring gear in the fire chickens?
Old Mar 17, 2011 | 08:15 PM
Oldsmobility85's Avatar
I was running a 4.10 with a 28" et street radial and going through the traps in the 1/8 mile at 6200 @ 100mph. Thats in 3rd gear with an auto. I assume you have a stick car.
Old Mar 17, 2011 | 09:04 PM
CamaroZ28_LS1's Avatar
yes all 10 bolt's in F-bodies are the weak *** 7.5" rear ends.
And I'd go with a 3.89 gears if your looking for decent 8th mile track gears. Just seems logical. I am sure you would hit 4th. I didn't like the top end with 4.10's... I'd hit like 130mph and had to shift into 5th... and I don't like to use over drive gears that much. That's not 130mph on a track lol. I run 3.75 gears as of now with my Moser 9".
Old Mar 18, 2011 | 01:24 AM
Yeah as if 130mph isn't fast enough. If you want to drag race and traction isnt an issue I highly recomend the 4.10. Its not too extreme and it will make plenty of axle torque to get the car moving and reduce short times.
Old Mar 18, 2011 | 11:40 PM
Brando5641's Avatar
this is for 1/4
Old Mar 18, 2011 | 11:50 PM
Well you really didn't give us any info for us to work with so I just told you my experience. You should probably just put 3.23's in it so you can race to 180+ mph.
Old Mar 20, 2011 | 10:06 AM
Brando5641's Avatar
yea and i can put neon lights under it and a coffee can.
Old Mar 21, 2011 | 11:22 AM
mynameisray's Avatar
YES! lol
Old Mar 22, 2011 | 04:00 PM
GT_EATR's Avatar
How much difference in the 1/4 mile would the 4.56 give me over the 4.10s? I have a 98 Z28 (M6) with cam/intake/boltons and 150 wet kit..
