Need some help
Anybody know what size the bolts and the threading it has so I can go pick it up at a local story or is there somewhere special I can order them from?Also I had a sensor on the top of the old 10 bolt housing but on the new one there isnt a spot to put it in at? What does this control and is it needed or can it just stay off?
Since your old rear had the sensor on the housing, that means you have the three channel ABS on the car without traction control. Your Moser rear was either ordered without any three or four channel, or it is a four channel. Are there reluctor wheels on the axles? In any case you won't be able to hook it up so you'll have to just do without your ABS. Your brakes will still work but you'll be able to lock them up if you slam on the brakes. You'll have the light on the dash glaring at you, which cannot be tuned out. You can remove the bulb though. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
