8.8 with abs and tcs
also is it easier to use the 10 bolt tubes o the 8.8 tubes? i have a 8.8 with 35 spline spool but haven't set anything else up yet. going to be installing the rear in the car this weekend.
1. A reluctor ring at each wheel (pressed on each axle) for the signal
2. Sensors installed at each of those rings to pick up the signal
The sensors are attached to the backing plates, so you need to figure out how to get them in the right position on the new rear as well as the reluctor rings on the axles in the proper locations. Probably easier said than done, but not impossible.
