Reluctor Ring
Old Apr 4, 2011 | 03:13 PM
jgb5129's Avatar
Default Reluctor Ring
Im trying to buy a reluctor ring (or rear wheel speed sensor) with part number 26029185. I've tried multiple websites and after i order they tell me that the part is either out of stock or is discontinued. Does anybody know where i could get one?
Old Apr 4, 2011 | 04:04 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
26029185 is a 3 channel 3 series reluctor ring. Typically you remove it off your old carrier and put it on your new carrier. Did you break it or building a complete spare rearend ?
Old Apr 4, 2011 | 06:45 PM
jgb5129's Avatar
My differential was very sloppy so i took it all apart and found the ring was cracked and a few gears chipped bad. i got an eaton and put in 3.73s and im driving it with the abs inop light right now.
Old Apr 4, 2011 | 08:47 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
it was discontinued by GM... you won't get a new one unless you are very lucky.
Old Apr 4, 2011 | 08:50 PM
jgb5129's Avatar
is there any place that you know of to get a used one? i tried ebay but couldnt find any.
Old Apr 4, 2011 | 08:55 PM
ssvert99's Avatar
put a wanted in the classifieds here... surely someone has to have an old 3ch diff laying around. the one you have is for 3.23/3.42 gears(usually 98-02). the 2.73-3.08 was different.
