Using only 1st & 2nd in the 1/4
Old Apr 9, 2011 | 11:55 AM
TurboAv's Avatar
Default Using only 1st & 2nd in the 1/4
Using a 28" tire. What if I used a 3.07 gear and went through the traps in 2nd gear? It works out about the same as using 4.56 gears and going through in 3rd. Just trying to see if I can keep my streetcar daily driver friendly.
Old Apr 9, 2011 | 08:21 PM
garygnu's Avatar
less wear and tear,lower rpms = longer life.the taller slick will grow and help with top end gear ratio.you probably will use 3rd gear.
Old Apr 10, 2011 | 05:33 PM
Supers's Avatar
Restricted User
You won't be setting down any full potential times as you won't be taking full advantage of your set up.
You could do that if you wanted
Old Apr 11, 2011 | 09:39 PM
89 formula350's Avatar
I would think its going to be a lot harder on the clutch
Old Apr 13, 2011 | 11:12 AM
TurboAv's Avatar
What clutch?
Old May 17, 2011 | 06:36 PM
TurboAv's Avatar
I'm still planning on doing this. Any more input?
