Identify gears
Old May 2, 2011 | 09:16 PM
Swiat34's Avatar
Default Identify gears
So I got some used (barely) 3.90 gears for dirt-*** cheap. they're obviouslt for a 7.5" GM 10 bolt. My question is how do I verify that they're 3.90s and how do I know if they're for a 2 series rear end or a 3 series? I have one of each housings so it only matters which one I put em in. Or should I say "have them put in," since I will be taking it to a shop.
Old May 2, 2011 | 10:00 PM
SS SLP2's Avatar
devide the # of teeth on pieion into the # of teeth on the ring,
the THICK ring is 2 series
Johnny
Old May 2, 2011 | 10:44 PM
Swiat34's Avatar
whats thick? like 3" compared to 1"?
thanks for your reply!
Old May 2, 2011 | 10:54 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
the difference between a 2 series 'thick' ring gear and a 3 series 'standard/regular' ring gear is about 9/32",which won't help you much in identifying which you have.
3.90s' for a GM 7.5/7.625 10 bolt are not that common and I don't recall ever seeing 3.90s' for 2 series,not saying they don't exist.
Old May 2, 2011 | 10:58 PM
Swiat34's Avatar
Sooo basically I better just crack open the cover and compare em side by side. Thanks guys. what marking on the edge of the ring gear should i look for and what do they mean?
Old May 3, 2011 | 06:12 AM
Motive would be G875390,a 3 series,they don't list a 2 series.
Old May 3, 2011 | 11:19 PM
Swiat34's Avatar
So is $250 a good price to have a shop install these gears? Dealership wanted $500 and didn't really want to do it anyway.
Old May 4, 2011 | 02:55 PM
Black 99 Bird's Avatar
$250 is not bad. You should be able to tell what series it is from by the part # stamped on the gear. "Thick" gears are usually followed by an "X" after the part #.
