will it bolt up?
Old May 14, 2011 | 10:48 AM
chris95lt1ta's Avatar
Default will it bolt up?
I'm going to pullapart tomorrow and they have a lot of 3rd gen fbodys. If I grab a rearend axle to axle will it fit and bolt up to my 95 t/a? If not can I just pull the differential and ring and pinion an bolt that into my 95 housing? In case I can't do either options above can't I pull just the ring and pinion , the 82-02 ring and pinion are the same right?
Old May 14, 2011 | 12:22 PM
Tobias05's Avatar
3rd gen axle too short for 4th gen housing.
82-02 ring and pinions are the same. 7.5=7.625. same gear, two seperate idiots with tape measures.
