Installing s60 any tips?
Old May 20, 2011 | 04:40 PM
chm2001z's Avatar
Default Installing s60 any tips?
I am installing my s60 this weekend. Was wondering if anyone had any tips or if there was anything odd they ran into. Any help would be greatly appreciated.
Old May 21, 2011 | 12:24 AM
Big Al's Avatar
Mine went right in. No problems at all. Used a UMI tunnel mount torque arm, had to do some hammering where the top plate on the torque arm mounts to the axle. It hit the floor. Not really a big deal.
Al 95 Z28
Old May 22, 2011 | 07:26 AM
98666's Avatar
get some friends to help its heavy
Old May 22, 2011 | 12:09 PM
studderin's Avatar
its a really easy install.
test fit your touqre arm on with the rear end on the ground 1st. Diffrent TA fit different some you have to grind on to fit some rearends. Its easier to check the fit off the car then tring to see if it fitting once its installed.
Old May 23, 2011 | 05:07 PM
chm2001z's Avatar
it actually was easier than I thought it would be. Thanks for the info.
Old May 29, 2011 | 08:48 PM
joblo1978's Avatar
