Building 9"...which housing ends?
Old May 22, 2011 | 05:14 PM
That Mopar guy's Avatar
Default Building 9"...which housing ends?
So I'm about to pick up a 9" housing and start a build to replace my 185K mile worn out 10bolt. Been trying to figure out which housing ends to get so I can still use the stock brakes. From the pics I've seen it seems like the aftermarket housing comes with the manufactures custom "small GM" ends that accept a 3.150 bearing. Then I assume you order custom GM axles that accept the 3.150 bearing with retaining plates to get rid of the C-clips?
Thanks
Old May 23, 2011 | 01:31 AM
wg871's Avatar
i'm interested in this also
Old May 23, 2011 | 01:54 PM
SS SLP2's Avatar
below is the answer, Bob will sell you the correct ends also the correct axels ( depends unpone you 3 rd member splines)
Johnny
https://www.brutespeed.com/index.htm
Old May 23, 2011 | 05:11 PM
garygnu's Avatar
you can buy a 9" housing and axle combo ,direct bolt .it will use all your stock brake stuff.check out some of the sponsors in here for parts and prices.
