building a 9" from scratch, info??
What I am looking for is links on measurements, if there is a place to buy a torque arm mount for 9 inch, and also what kind of brake setup options to run? Thanks in advance
not a bad job if you have the time and good help
Johnny
. I also bought a complete third member for the 9" used, Mark Williams (Aluminum) Thru bolt centersection for the 9" with a 40 SPLINE SPOOL ,3.70 PRO gears ready to go for $1,000. Later
