10 Bolt Question.
Im talking like moser axles, gear, dif, and all those goodies. Any suggestions?
Lighten up the car and run low gas levels in the meantime
LPW girdle,solid crush sleeve,weld your axle tubes and run a GM gear set is what you can do in the meantime if you can find the gears(find out who they were set up) and girdle used.
