which lugnuts to get
Old Jun 19, 2011 | 02:25 AM
+badss+'s Avatar
Default which lugnuts to get
i am about to swap in my s60 into my 02 camaro ss. i am keeping my factory chrome 17 inch rims. so my question is the rear has 1/2 studs (long), what are my options for lugs? would these work. http://www.summitracing.com/parts/SUM-7540026/ thanks for any help i can get...
Old Jun 19, 2011 | 10:00 AM
oldguy99Z's Avatar
Yes those lug nuts should work fine.If your factory wheels have the plastic caps over the lug nuts and you want to keep them you will need a oem style external thread lug nut in 1/2" size and then the bigger lug nut will need the larger size cap like GM trucks use.BTW the larger caps fit over the long studs on my 12bolt.
Old Jun 19, 2011 | 11:44 AM
+badss+'s Avatar
anyone have any links or part numbers, or pics of what your using on your ride.
thanks
