Remove Brake Backing Plates From 9"???
Old Jul 11, 2011 | 06:54 PM
105's Avatar
105
Default Remove Brake Backing Plates From 9"???
I'm trying to get the backing plate and e brake off of the 9" rear. I'm guessing I might need to remove the axles first. How exactly do you remove the axles. I did read a post where someone said to just tap them out with a hammer, but that didn't work for me. Do I need to open up the rear first for something?
Old Jul 12, 2011 | 04:24 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If it is a Moser nine inch you need to unbolt the brake backing plates first. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 12, 2011 | 07:12 AM
105's Avatar
105
I was thinking there is no way I could get any kind of wrench in there. Now that the rear is off the car this should be fun. Do you use a flexible box end wrench?
Old Jul 12, 2011 | 07:27 AM
RsSean's Avatar
Remove calipers, remove rotors, remove the 4 15mm bolts that hold the backing plate to the axle tube. gently tap out the axle. After the axle is out you must remove the bearing/wedding ring assembly. Then the backing plate with come off.
Old Jul 12, 2011 | 07:34 AM
105's Avatar
105
My big question is how do you get to those 4 backing plate bolts?
Old Jul 12, 2011 | 11:31 AM
heymoej's Avatar
i believe we used just a regular old wrench.....
some of the bolt heads on mine were ground round to fit the contour of the tube,so on some i used the box end & open end for the others.....
Old Jul 12, 2011 | 12:29 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
With the brakes removed and including the parking brake pads they can be reached rather easily.
Old Jul 12, 2011 | 01:05 PM
105's Avatar
105
Ah, okay! I'll have to take a closer look again, as I didn't see a way to remove the parking brake pads. How is that done exactly?
Old Jul 12, 2011 | 01:15 PM
Pull up on them. Trust me when I say they are harder to put back on than they are to get off..
Old Jul 12, 2011 | 06:00 PM
105's Avatar
105
Ok, now how do I get the axle bearings off? Do I need to take the axles to a shop?
Thanks for you help so far.
Old Jul 13, 2011 | 12:58 PM
Yes a press would be the best/correct way to remove them.
Old Jul 13, 2011 | 01:01 PM
105's Avatar
105
Awesome, thanks.
