checking backlash, which way to move ring gear??
Old Jul 14, 2011 | 04:34 PM
vbls's Avatar
Default checking backlash, which way to move ring gear??
im trying to check backlash, i have the dial indicator setup,i tried to move the ring gear back and forth and side to side, it only wants to spin.
any help is appreciated
Old Jul 14, 2011 | 04:47 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
it is a very 'small/tiny' movement you're trying to measure !
let's say you're trying to measure .008" backlash on a 7.625 ring gear,that equates to only 1/8 of a degree,a very small amount of movement.
if your pinion preload is 10-30 in.lbs,that should be enough to keep the pinion from rotating while your watching the indicator.
or somehow hold/keep the pinion from rotating(absolutely no movement) and then watch the indicator while you're moving the ring gear back & forth.
check in a couple places to verify no runout.
Old Jul 20, 2011 | 10:45 PM
Nebulus's Avatar
Moving the ring gear towards the pinion will reduce backlash and tighten it up. Away will increase and loosen.
