Whine in the rear....
If Your trying to pinpoint which side the noise is coming from try an empty parking lot, turn one way and hold the car in the corner for a bit, then repeat turning the other direction. One direction will typically be louder than the other. If it is louder while turning left then it is the right side making the noise and vice versa.
Hope this helps.
I know the mistake I made when i had it apart is I didnt check on the carrier bearings but they were all replaced back in november when i had the rear done, or so I know, it was done at a shop. I guess I will take it back apart tomorrow evening and check them, but how would I know if one of the bearings are bad, is it visable?
