am i getting ripped off?
Old Oct 5, 2011 | 03:35 PM
nik1703's Avatar
Default am i getting ripped off?
Diff blew up recently, took it to a shop for a rebuild. It's just a standard 10 bolt with 4.10 gears.
They want 1500 for a complete rebuild with a 1 year warranty? Is it just me or is this price insane? I can get a used 10 bolt for a few hundred bucks.
Old Oct 5, 2011 | 03:40 PM
nik1703's Avatar
also can anyone point me towards a reputable diff place in LA?
Old Oct 5, 2011 | 03:42 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Probably a bit high, but it's in the ball park of what I'd expect to pay to have a blown up 10-bolt rebuild. That's why most people look for a cheaper way to put in an upgraded rear end (like one from a junk yard that is modified to fit) or they buy an upgraded unit (12-bolt, 9 inch, or Dana 60) since it isn't that much more, especially since the ten bolt will break again.
This belongs in the Gears & Axles section BTW. I'd move it myself, but don't have the privileges in this section.
Old Oct 5, 2011 | 03:43 PM
Mean87SS's Avatar
Sounds like you need a 9"...
Stippy17's Avatar
If they are doing a complete rearend rebuild that sounds about right. Labor + parts add up quickly when rebuilding a rearend, transmission, or engine.
Old Oct 5, 2011 | 03:44 PM
Undertow74's Avatar
I already knew the answer when i saw the title, Yes. You would be better off saving the extra cash and get a fab9. any shop is going to eat you alive in the cost of labor. now getting technically ripped off, no the cost of labor+parts+warranty sounds about right, but for a stock 10bolt you would be better off paying a few hundred yourself and getting a new gearset, if thats all that blew up. remember everything today is expensive as **** if you have someone else do it....
Old Oct 5, 2011 | 03:47 PM
nik1703's Avatar
they're telling me it needs a complete rebuild (ring,pinion,housing, etc etc).
of course that's what they say.
what do you guys think i should do? i dont want to spend 2k (rather, i dont have 2k to spend, lol) on a 9/12bolt.
should i go to another shop, or just get a used 10 bolt for a few hundred and put it in myself?
anyone have a writeup on doing a standard diff swap?
Old Oct 5, 2011 | 03:51 PM
Undertow74's Avatar
The cheapest route to go would be to pull a rear from the junk yard, or to order a new gearset& cover( that is as long as your actual housing/axle tubes are not cracked) if you do not know how to rebuild a rear, some shops you go to will do it for you(but most wont unless THEY provide the parts)
Old Oct 5, 2011 | 03:55 PM
nik1703's Avatar
i have a writeup on how to rebuild one, but i have never done it before. I'll have to ask the shop whats up with the axles/housing.
im also not seeing much in the classifieds on here sadly.
Old Oct 5, 2011 | 03:57 PM
LS1WS6dreamer's Avatar
Yeah I would have to go with a junkyard rearend. I would have to take a freakin loan out to spend $1500 on a 10 bolt.
Old Oct 5, 2011 | 04:01 PM
MeentSS02's Avatar
Back in the day, I sold my used 10-bolt (fully functional) for around $200 or so. If you don't have the money to spend, you'll just have to wait for something to pop up, or go find one in a junkyard and hope for the best.
Old Oct 5, 2011 | 04:06 PM
nik1703's Avatar
that is the plan.
Thanks for the input guys.
last thing, i assume all 98-02 10bolts will fit properly with my 98' car? are there any other years that will fit?
Old Oct 5, 2011 | 07:02 PM
MeentSS02's Avatar
You'll just want to make sure you get one that has the same ABS/TCS setup as your car - if your car doesn't have traction control, you'll want a 3 channel (sensor on the pumpkin). If it has traction control, you'll want a 4 channel (one sensor at each wheel).
Old Oct 5, 2011 | 10:45 PM
01ssreda4's Avatar
I'd source all the parts used and then A. pay them for labor only, or B. buy a press and a few tools and do it yourself.
Old Oct 14, 2011 | 04:57 PM
nik1703's Avatar
well picked up a used 4channel 10 bolt today with 3.23's for $240.
got a set of 3.73's (used, GM) for $75, drove down to the shop and dropped all that **** off, they're going to install everything (and pack new gears) for $450, which isnt that bad, considering i get my old axle housing, diff, axles and 3.23's out of the new axle back. i can probably sell all that for $200.
then, had this shipped to the shop:http://www.ws6project.com/user_stor/...tallation-kit/
Overall, pretty successful day, considering I drove all over west and east LA picking up all these parts, and delivered them to the shop in 2 hours on my lunch break.
so, everything should be done by tuesday.
Old Oct 14, 2011 | 05:11 PM
TransWS6Am's Avatar
sounds like alot of money for it to break again.
Old Oct 14, 2011 | 05:17 PM
nik1703's Avatar
Ok, well $240 for the whole axle (with calipers, rotors, and gears), then $75 for another gear set is a good price.
The big money part here is the gear install kit ($80) and then $450 for the labor on swapping the diffs and swapping the gears.
so overall i spent $315 on parts, and 530 on labor.
minus maybe, $200, for what i can sell the left over parts for, i'm out about $645 bucks. that's a hell of a lot cheaper then a $1500 rebuild.
left over parts: two calipers, two rotors, 3.23 gear set, two axles, 1 axle/diff housing with wheel hubs
