10 bolt rebuild...
http://www.ws6project.com/user_stor/...rential-misc-/
with 143k miles, you need the deluxe because your wheel bearings are probably bad.
They sell ring and pinions too just make sure you get the right one depending on if you have a 2 or 3 series (should be a 3 series so everything they have listed that doesn't have 2 series should be fine). I would get 4.10's since its a six speed and it wont hurt DD'ing that much and still give you a decent upgrade.
75W90 NON synthetic Gear oil and the limited slip additive (GM or Ford). I've heard the ford additive is a little better but I can't say I noticed a difference.
Get a solid pinion spacer and a TA girdle if you want it to hold up a little better.
That should be it. If you plan on having someone do it it'll probably cost you $250 - $300 in labor alone. It aint cheap man and make sure they do it right. If it whines, ask them what they set the gear backlash to and check it again. Good luck man.
The pinion spacer acts in place of the crush sleeve and resists deflection and helps make the 10 bolt last longer.
The girdle is another thing that will help strengthen your rear end.
Both of those things are pretty much a must doing a rebuild because you don't want to have to do it again and for the money, they are great additions.
If you don't do the girdle at least spend the extra $20 on the pinion spacer because the rear is already apart and it helps a lot. The girdle you can do later when you do a rear end flush. Good luck man. I can't recommend anyone in nashville because I got mine done while I was in knoxville by a local guy that did a decent job. I'm sure if you post on the southern members board then you could find someone close. Good luck man.
I had a horrible experience with the 10 bolt in my 3rd gen. Initially was just a "budget" upgrade from an open 2.73 rear end. But, by the time I'd gone through 3 different shops and 3 different gearsets to finally get it done right I could have bought a 9 inch instead. Makes me sick thinking about it.
Finding a low mileage 10 bolt is pretty hard to come by. I dont think anyone would rebuild one just to sell it. They just wouldn't get their money back. There's always trying but good luck.
