Moser 9" Wavetrac Diff Problem?
Old Oct 9, 2011 | 08:10 PM
DoggyB22's Avatar
Default Moser 9" Wavetrac Diff Problem?
So I just installed my Moser 9" with a wavetrac diff & when I make right turns something is vibrating like crazy! Even when I turn the steering wheel slightly to the right it goes crazy. I know that they make noises but I wasn't expecting this? Two of the studs are a little crooked but I wouldn't think that would cause all the noise? Any ideas.... Oh yea & I love my new rear end!
Old Oct 9, 2011 | 09:01 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Check to make sure the torque arm mount is not rubbing on the bottom of the chassis. There are two places where it typically rubs at, and if you shove a pry bar up in these areas you can nudge the floors sheet metal away. If it is rubbing, it tends to make more noise when turning. The Wavetrac should make zero noises. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 9, 2011 | 10:08 PM
DoggyB22's Avatar
Thanks yea I was able to really look at it & the rear passenger side tire is pretty much in the inner fender so Ill bang it out some more tomorrow so it can clear.
Old Oct 10, 2011 | 06:11 AM
LS1Tech Sponsor
That could do it for sure. Bob
__________________
Old Oct 10, 2011 | 08:35 AM
69TA's Avatar
I like your picture with Osama and Sadam
Old Oct 10, 2011 | 02:06 PM
DoggyB22's Avatar
What would cause it to rub now then before when I had my 10 bolt?
Haha thanks!
Old Oct 10, 2011 | 03:44 PM
69TA's Avatar
the lugs should not be crooked.
I know it sounds crazy
but when you mounted the wheel back on, was the rear hanging down?
maybe the rim was up against the bumpstop and not actually fully seated against the axle.
Old Oct 10, 2011 | 03:54 PM
LS1Tech Sponsor
Question
Haha thanks!
Does the rear look centered? Bob
__________________
Old Oct 10, 2011 | 04:16 PM
DoggyB22's Avatar
Yea I gotta take the wheel off & check it out..
Looks pretty centered to me? Haha its just both sides don't really have a lot of breathing room for the tires now compared to when I had my 10 bolt. The front of the rear inner fender is def touching the tire & the driver side inner fender has like a finger nail of length between the tire & fender. I mean I guess when I get a chance bang out the inner fenders some more. I'm not driving it that's for sure. Surprised the tire did pop. I mean I guess I can try taking pics if that makes it a better visual for you guys?
Old Oct 10, 2011 | 04:17 PM
LS1Tech Sponsor
Question
Did you order your rear narrowed? Bob
__________________
Old Oct 11, 2011 | 12:02 AM
DoggyB22's Avatar
I don't think it is... I bought it from a friend. But its been raining all day today so I'm bang out the inner fenders tomorrow & see if I still have problems
Old Oct 11, 2011 | 06:25 AM
LS1Tech Sponsor
I bet it is an inch shorter per side than normal, as the tires should normally be where they are with the old 10 bolt. A lot of people order these rears slightly shorter and use a different offset wheel. Bob
__________________
Old Oct 11, 2011 | 09:52 PM
DoggyB22's Avatar
Banged out my inner fenders some more & also had to bang right above the bump stop... Was rubbing pretty good there also
Old Oct 14, 2011 | 03:25 AM
DoggyB22's Avatar
Is it normal for a clunk noise every time I upshift? But when I downshift its fine. Also there's a whining every time I give it some throttle when I'm on the hwy?
Old Oct 14, 2011 | 04:28 AM
LS1Tech Sponsor
No, there should be no clunks. Are you sure this rear that you bought from a friend actually has a Wavetrac?
The first thing I would do is check your universal joints and then the torque arm. A little gear whine is to be expected with performance gears. Bob
__________________
Old Oct 21, 2011 | 02:27 PM
DoggyB22's Avatar
So I ran into a problem couple nights ago when I went to the strip. After I made a pass & pulled off the track I could hear my passenger side was rubbing again pretty bad. When I got back to the parking lot I did some turns & U turns and could tell it was def rubbing. Then I heard this pop noise. So I stopped asked a fellow guy if he could let me use his jack so I could take my tire off & check it out. It was really rubbing on the rim right above where the bump stop is. So I banged it in some more put back on my tire. Did some more turns & U turns. Heard another pop noise. But wasn't rubbing any more. But every time I would turn you could hear a squeaking noise? I mean I drove it an hour & half back home so its drivable but just some squeaking problem & I don't know why it had that rubbing problem after it was fine before I got to the strip... any thoughts?
Old Oct 22, 2011 | 04:43 AM
LS1Tech Sponsor
The panhard bar locates the rear side to side, I'd check it out to see if it is bent. Bob
__________________
