Ford 9" center question
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The Strange aluminum center section actually is $379.00 but still a lot of dollars for 20 lbs.
Carl
When a customer calls and wants to drop a bunch of weight off their rear end I try to ask them if chasing tenths is worth the money spent. But to make a difference you really need to stack up a bunch of weight savings to make it worth wild and in doing so it usually means a substantial amount of money spent as well after you are done taking out the free weight.
Also keep in mind the Strange aluminum light weight case is not designed for high HP heavy vehicles. It is also not good for a bunch of street driving either. Now don't get me wrong I have plenty of customers doing it but the problem you will see is premature gear wear from case flex. An aluminum case is also known to let out a little more gear noise also.
Hope this helps.
