rear end abs
You can use a non-abs rear, and that will disable ABS completely. How much does that matter? Some people hate abs, and there are kits to delete it. It will fall back to a default brake bias, though I can't recall when that proportioning is.
There are several clip that hold the brake lines to the existing existing axle, along with a bracket that attaches to the flex lines to the housing from the body. When you're done putting the new axle in attach the lines to it.
