Wheel Stud replacement?
Old Feb 2, 2012 | 01:52 PM
Huntr1117's Avatar
Question Wheel Stud replacement?
I have to pull the axles out to replace some broken wheel studs. I can't knock the broken studs out past the reluctor even if I take out the TCS/ABS sensor it still hits the ring. I've read that there is paddle to take out to get to the c clips or it's a pin. Which one is it? Is there anything else I should be replacing while I have it apart? The car is a 96 TA with TCS. I think that would make it a 4 channel
