Strange 12 Bolt Question
Old Feb 4, 2012 | 07:35 PM
1961ba427's Avatar
Default Strange 12 Bolt Question
Does Strange cast all the F-body housings with a hole for a 3 channel ABS sensor even if the rearend was not ordered for one? I'd think they might build them all the same and just ship them with the hole plugged for people with 4 channel ABS or No ABS. Also, if any of you could answer the same about Moser housings as well, but mainly need to know about Strange.
Old Feb 5, 2012 | 01:05 AM
01ssreda4's Avatar
Call Strange and ask them.
Old Feb 5, 2012 | 04:51 PM
1961ba427's Avatar
I guess I'll have to do that tomorrow. Figured plenty of people on here could answer from experience.
Old Feb 5, 2012 | 08:36 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
I am pretty sure both the S60 and 12 bolt have the 3ch ABS sensor provision machined into the housing. If the rearend is ordered as a 4ch setup, then they just install a freeze plug into the hole.
Old Feb 5, 2012 | 09:32 PM
1961ba427's Avatar
Thanks for the reply. I've been looking at a car with a strange 12 bolt and a spool, but it's not close by for me to check. If I pick it up, I plan on swapping a posi and 3 channel reluctor/sensor in if the housing is machined for it.
