gear choice
Old Feb 27, 2012 | 08:58 PM
Blown02Camaro's Avatar
Default gear choice
Iv got a 12 bolt with a 4:10 gear in it. At the moment i'm having a 383 stroker built and am hoping for 600-650 at the tires. Whats a god gear for the street and for the track?
Old Feb 27, 2012 | 09:02 PM
Zmg00camaross's Avatar
Auto or M6?
Old Feb 27, 2012 | 09:18 PM
M6
Sorry forgot to mention that
Old Feb 27, 2012 | 10:14 PM
4.10 would be a good gear for that much power. Depends on how much street and how much for track.
Old Feb 28, 2012 | 06:29 PM
It'll be mainly be street car with occasional track use
Old Feb 28, 2012 | 06:45 PM
guppymech's Avatar
The word is at the track you want to go through the traps a few hundred rpm above the power peak for max performance.
There's a good gear calculator at f-body.org
4.10s with a 28 inch tire will get you 132 mph @6500 in 4th gear. Or 4.30s 132@6800
You're probably going to have to wait till the build is done to see what the hp curve looks like before making a final gear choice. 4.10s are probably in the ballpark.
Old Feb 28, 2012 | 07:13 PM
would a 3.73 with the right sized tire be a better choice?
Old Feb 28, 2012 | 07:24 PM
guppymech's Avatar
From what I've read, a normally aspirated car works better with higher numerical gears ex 4.10-4.56. From your username are you going to use a supercharger or nitrous? If so it seems most people use lower numerical gears like 3.73s All this info is biased twards maximizing performance at the drags . For street use I don't think it makes a huge difference. You could keep the 4.10s and see how they work and adjust from there.
 Michael S. Palmer
Old Feb 28, 2012 | 08:39 PM
Im going turbo. The car has gone a 12.034 @117 with the 4.10 i didn't know if having that higher gear would be ok when trying to keep in boost longer
Old Feb 29, 2012 | 05:13 AM
guppymech's Avatar
I've read some very informative posts by member CALL911 on gearing. He's got a procharged 383 M6 making 614 rwhp, perhaps he could give you some advise.
