What goes first?
New around here but reading everything I can. I've been in the GTO scene for a while but am fairly new to live axles. I'm planning a turbo M6 fbody build and I'm focusing on the rear end right now. I keep reading over and over that the 10 bolts are weak, they'll break with power and especially an M6 in front of them, they're weak, they're weak... my question is what's the weak part? Is it the 7.5" ring and pinion?
Corollary to that is the next question- is there any strength advantage to going to taller gears? I've only followed people putting in 3.73s and 4.10s for NA cars but I would consider going to an A4 rear to build boost. Is there a possibility that, if the gears really are the weak point, that going to something taller will be stronger, following the line of logic that fewer teeth = stronger teeth? I know an A4 is easier on the rear but perhaps part of the reason why they're slightly less prone to dying is the taller gears?
http://www.ws6project.com/user_stor/...oducts_id=4539
That's about all there is in the "cheap and easy" category.
heres mine after a 2nd gear pull right on the edge of breaking 295s loose
^also had a girdle
