Which carrier shim kit?!
This is the one that came up when I searched via vehicle
http://www.jegs.com/i/Motive+Gear/683/1105/10002/-1
This one as similar item
http://www.jegs.com/i/Richmond%20Gea...0002/-1?CT=999
This one searching vehicle, lists that it works for both
http://www.summitracing.com/parts/RA...n/?prefilter=0
Or if there are any others? Sponsors?
TIA
a 7.625 rearend has a 7.625 OD ring gear mounted on a 7.5 carrier.
a 7.5 rearend has a 7.5 OD ring gear mounted on a 7.5 carrier.
rearend parts are the same: bearings,seals,shims,etc.
Also, does anyone know the break in procedure for Richmond gears?
I found this:
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for 30 minutes. Do this 2 to 3 times.
Does this sound right? Anyone with experience?
