almost back on the road, one last question
try this
http://www.wallaceracing.com/Calculators.htm
Johnny
thanks for that link there is a lot of helpful stuff in there.
sounds like from the way it's worded that you're gonna replace the ring gear only and not the pinion gear. Ring and pinions are matched sets from the gear manufacturer.
Ring gear to carrier fit is typically a slight interference fit. With the ring gear bolts loose but threaded in a few turns,hitting/tapping the bolt heads will 'walk' the ring gear off the carrier.
