vibration and howling
Like the title states, that's the issue I'm having. SO I replaced both axle bearings with timkins. Noise is still there. I couldn't get my pass.side axle back in so easy, so I loosen up the bearing caps for that side and looked up online tq speq of 85ft lbs to tighten them back up, but they just keep turning, tq wrench never clicked and I know it was over 85 ft lbs... so i questimated by un doing the left side cap bolts...
WELL, the same noise is there. I do have a leak from the pinoin. there's oil on u-joint and tq arm. is there a bearing on the pumpkin for the pinoin???
Any info, please help.
Thanks in advance
