How hard is it to get reluctor
Old Apr 9, 2004 | 08:25 AM
HumpinSS's Avatar
Default How hard is it to get reluctor
rings off the axles. Doing a axle replace this weekend and need to know what i am up against
Old Apr 9, 2004 | 07:01 PM
PHIL H's Avatar
Its super easy...You do NOT have to take them to a shop and have them pressed on and off. Simply use a decent size prybar and gently pry it off evenly around the whole axle. It comes right off. I've done it 4 or 5 different times and have had good luck with it. On reinstalling just use a hammer and gently tap it back on evenly. Use a block of wood if you are concerned..
Phil
Old Apr 10, 2004 | 06:18 AM
HumpinSS's Avatar
Thanks I will start the swap in approx 3 hours EST
