273's
Old Dec 16, 2012 | 09:07 AM
lrmneil's Avatar
Default 273's
Are any of you guys running decent times with the stock 273?
Old Dec 17, 2012 | 10:25 AM
reeperz28's Avatar
No, cant wait to get rid of myne. I have a 2800 stall with 2.73 rear gear and the best 60 ft is a 2.1. Fpr as drivabilty with a aftermatket cam its hurting gas mileage but its highway mileage is phenominal haha.
Old Dec 17, 2012 | 11:08 AM
Lt1Powerz's Avatar
Im swapping out my 2.73's since i blew my rear end but they suck bad! No top end whatsoever.
Old Dec 18, 2012 | 04:10 AM
justin hover's Avatar
This just goes with your title..."suck ***" Everyone says track times hardly vary when doing a 2.73 to 3.73 swap. But it truly "feels" like you pick up a second. Daily driving is alot funner comparably from 2.73s to 3.73s and thats a fact.
Old Dec 20, 2012 | 08:49 AM
Roarin_8's Avatar
With stock cam they did great with the converter (1.70 60'), with aftermarket cam, not so much, (2.4 60').
Here's the vid with the 2.4 60', run was a 12.5 @ 113
http://www.myspace.com/video/roarin-...ne-run/2633897
Old Dec 20, 2012 | 09:39 AM
lrmneil's Avatar
Nice thanks man.
Old Dec 20, 2012 | 09:40 AM
lemons12's Avatar
Buddies setup.. 98 FULL weight trans am.. stock lid 273s etc etc
228r tsp cam
ptc 4000 converter
pacesetter long tubes, 2.5" x, 1 chambers dumped
untuned in fl heat it ran 11.8@114mph
In tn untuned before the cam it ran 7.7@88 in tn
Gears matter very little in stalled autos vs manuals.. I suggest a stock 342 rear if you feel the need to switch.
The actual et/mph gain from the two is minimal at best.
Old Dec 20, 2012 | 09:45 AM
lrmneil's Avatar
228r tsp cam
ptc 4000 converter
Nice I knew it could be done!
Old Dec 20, 2012 | 09:54 AM
lemons12's Avatar
I've seen heads cam 323 cars cut 1.4 short times.
Old Dec 20, 2012 | 09:59 AM
babbage1109's Avatar
Best sixty foot I ever got out of mine bolt ons full weight stock stall was 2.01 on street tires
Old Dec 20, 2012 | 10:05 AM
lemons12's Avatar
You guys running street tires might as well not post up.
You aren't going to lose .7 in the 60' by changing to any cam either any gears, period.
Old Dec 20, 2012 | 10:23 AM
lrmneil's Avatar
Nice............
Old Dec 20, 2012 | 11:30 AM
Got the same sixty foot with slicks. so its relevant.
Old Dec 20, 2012 | 01:59 PM
lemons12's Avatar
I cut 1.9s in a stock 98 running 8.4s... Added an ms4 cam, full exhaust, 4400 converter.. Ran 7.5s cutting high 1.5 short times..
This was with 323s but the principal still applies to 273s.
That post about street tires wasn't towards you babbage, its the guys with converters/etc.. If you're spinning its not worth posting results.
Old Dec 20, 2012 | 02:08 PM
Oh okay. Yeah I def never spun. Launching at 1700 with a stock stall.
Old Dec 21, 2012 | 06:46 AM
1967BuickGS400's Avatar
I did the swap in my 71 skylark with a 455 big block. Went from 2.73 to 3.42. I got the same 60ft. and same et but 2 mph slower with the 3.42s. But like someone said before it feels faster.
Old Dec 22, 2012 | 11:05 AM
roy's Avatar
roy
There is an Austrian overhere with a tubocharged LSX Camaro topending on high speed runs with 2.75 in a Ford nine inch ( 240+ mph). Speed can be made with these gears if you have the HP.
Old Dec 26, 2012 | 10:20 AM
Roarin_8's Avatar
Most guys on here are looking for quickness. Doing a certain distance in a certain amount of time as quickly as possible. We don't have the autobahn over here
