Anyone else having this problem?
Old Dec 25, 2012 | 02:53 PM
Fasrnu's Avatar
Default Anyone else having this problem?
Ok I am having trouble with my 9 inch leaking at the axle bearing right behind the breaks ..filling the breaks and the wheels with gear oil. I have already checked the vent tube even tried sealing them up with RTV. It might be a little over full but nothing crazy i have the standard fill plug any suggestions or input would be greatly appreciated
Old Dec 25, 2012 | 06:02 PM
therabidweasel's Avatar
This is a common problem...you likely need to replace your axle seals...some are easily damaged on install. Might also check to make sure the vent is clear...if its not that could blow the rtv out of the seal. The seals themselves are tupically put in with ultra black or similar.
