What gear ratio
Old Feb 8, 2013 | 11:28 PM
Mrmooney's Avatar
Default What gear ratio
Car is a M6 28" tall rear tire.
76MM turbo right now making mid 500's to the rear.
Going to turn it up once I get a new rear end goal right now is 650-700 to the tire( havn't decided what im going with yet ) street / strip car.
What do you guys recommend?
Thanks
Old Feb 9, 2013 | 11:32 AM
guppymech's Avatar
Probably something in the 3.50 to 3.73 range. What mph and rpm do you expect to trap at? What is the peak hp rpm?
f-body.org/gears calculator,
28" tire 6k rpm with 3.73s=134mph
You've got some figgerin' to do.
Old Feb 9, 2013 | 10:43 PM
LS1T56FTW's Avatar
Do you plan on tracking the car a lot? Long gears are great with turbos. If you plan on doing highway pulls and such, a 3.42 gear like stock would work great. If you plan on tracking the car more a 3.73 or even a 3.90 may work. A local made 695whp thru his turbo LS1 and with 3.73s and a stick the gears matched quite well.
Old Feb 10, 2013 | 12:47 AM
Mrmooney's Avatar
i'd say 70 % street with highway rolls 30% track. Of couse i say that.
Right with stock rear and 3:42 is pretty damn good right now. turing 1700ish RPMs at 70mph. Car is pretty quick from a 50 roll leaving in second. Maybe ill stick with 3:42 ish.
Old Feb 17, 2013 | 03:58 PM
mikh338's Avatar
im pretty much in the same boat, will be running 28s with a m6. car now has 4.10s and n\a but am purchasing the on 3 turbo kit soon and will need to change gears also. looking to make 600whp ill be more then happy with that
