Pinion nut, how tight?
Old Apr 3, 2013 | 04:43 PM
TXCatfish's Avatar
Default Pinion nut, how tight?
Anyone know how tight this needs to go back on? And is it okay to reuse the pinion nut??
Thanks
Old Apr 4, 2013 | 01:35 AM
01ssreda4's Avatar
You tighten it (using an old crush collar) to the same spot or 1/16th tighter OR (using a new crush collar) to the correct SPINNING drag on the pinion bearings....20-25 inch/pounds IIRC using a beam style torque wrench. I've never re-used a crush collar and you really aren't supposed to but some will say it is acceptable.
