spools
Old Apr 22, 2004 | 12:23 PM
byarddog's Avatar
Default spools
I hope to be buying a ford nine inch with a spool in it. Are spools best for the strip and can they be driven on the road with the only thang hurting is the tires wearing out. thanks
Old Apr 22, 2004 | 01:07 PM
SilverGhost's Avatar
Motorboater
i replaced my locker in my 9" with spool..its on its way so i'll know soon.
best for strip yes..will a bit of a pain on teh street if you are not on a slick
Old Apr 22, 2004 | 05:40 PM
00Streak's Avatar
I run my spool on street each day to and from work. It isnt to bad. Just avoid tight turns and give it gas all thru the turn. It is eating my eagle f1 gsd3's for lunch tho. but I dont mind. summer time I spend on 2 wheels most of the time anyhow.
Old Apr 27, 2004 | 11:53 AM
Noyzee's Avatar
8 second mod
go spool, it is good. just tight turns.
i drive mine alot and it isnt bad.
Old Apr 27, 2004 | 12:07 PM
next's Avatar
I found that if you pay attention to how you're taking corners it helps alot. The real challenge is how it eats tires at slow speeds, but it's still the only way to go for a solid track set-up.
Old Apr 30, 2004 | 08:48 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
I run a spool and its the only way to fly. And i run et streets no problems here
Old May 3, 2004 | 02:56 PM
Noyzee's Avatar
8 second mod
i love my spool, but again tight corners are a bit iffy, but worth the trouble!
