who has done a 8.8 swap, step in plz
When you went from the stock 10 bolt to the 8.8 besides the flange to bolt to the 8.8 does the driveshaft need to be longer or shorter?? Or was no length change needed?
Not all stock drives hafts are aluminum and yes it does matter. Did a Th400 swap and I want to drive my car now and not buy two drive shafts before the rear is ready in a couple months. So if I can order one now for the 10 bolt and later just do the conversion joint I can drive again until then
