Help, will it fit?
Old Jun 1, 2013 | 08:54 PM
Carguy8888's Avatar
Default Help, will it fit?
I purchased a 3.42 10 bolt a few months ago from a guy who said it was a 4 channel.I didn't know any better and apparently neither did he.It turned out to be a 3 channel from a lt1. My mechanic saw it immediately when i showed him the rear today.are the brakes and backing plates interchangeable?I guess I will have to chuck the traction control unless i want to have the entire rear rebuilt.
Old Jun 1, 2013 | 09:13 PM
01 Vert ws6's Avatar
swap the axles and backing plates
Old Jun 1, 2013 | 09:32 PM
Carguy8888's Avatar
My guy said the same thing but was not sure the would swap only because he never did it.No problem everything fits? I guess I will have to pull the tc bulb?
Old Jun 2, 2013 | 07:11 AM
The axles out of your old rear have abs splines behind the axle flanges , that's behind where the rotor fits , the sensor mounts on the backing plate
Old Jun 2, 2013 | 04:33 PM
Carguy8888's Avatar
Very glad to hear it will work. He said I will loose the t/c which is fine but I can't tune out the light. I have to pull the bulb from behind the dash. Hope that is not too much of a pain? Thanks for your help. Brian.
