im getting an 8.8" need help.
For the basic package you get your choice of any ratio ring and pinion available for an 8.8" housing. Also included is your choice of posi unit "Eaton HD, Auburn, or Torsen carriers" Moser 31 spline axles with 3"x 1/2" x20 studs (stock length is also available if requested), a new 1330 yoke and of course all new seals and bearings. We also include a conversion u-joint. This axle is completely compatible with any 4 channel ABS system, we also have a 3 channel version now. The basic price also includes bolt in axles, required for cars running faster than 11.99 in the 1/4 mile or 7.50 in the 1/8.
We also offer several different options:
If you opt not to use the ABS system you can deduct $100.
If you do not want bolt in axles then deduct $150
Detroit locker for $250
1350 yoke $115
T/A girdle (highly recommended) $150
Stud kit for main caps $25
And our laser cut lower control arm relocation brackets for $100
the locker is'nt for everybody, auburn is not rebuildable, torsen is more suited to road race.
get the bolt in axles..uses 9in bearings besides the c-clip eliminators the 9in bearings are bigger than stock 8.8 stuff i.e stonger.
the h.d yoke, studs, and girdle are wise choices if you are planning to abuse it often(it's just for show, honest
)i'll leave the brackets up to you.
