Rear rattle/knocking
Building another 10 bolt over the winter with 3.73's, relocation brackets and a gurdle. Need the know is there something I can do with the new rear to prevent this from happening again. Thanks
loose or missing ring gear bolts(they're left hand thread)
loose or missing torsen end cap bolts
pinion rotational marks on the torsen case
is the torsen moveable left/right to indicate bad carrier bearings
(Whether they are in our weak 10 bolts, or even something MUCH MUCH stronger.)They were first and foremost designed to be a cornering/handling aid type diff, at least the high bias T2R had this in mind (the stockers on '99-'02s were T2s).
