gearing
Old Oct 30, 2014 | 07:17 PM
wannabeturbo's Avatar
Default gearing
How much would changing from 3.73 gears to 3.27 gears change how the car 60 foots
Old Oct 30, 2014 | 08:36 PM
karpetcm's Avatar
I'm on my phone so if there is a Sig I can't see it. What mods do you have, tires and suspension?. There are many factors. Do you have an A4?. It will help us give you a better idea. Also what's making you go from 3.73's to 3.27's, just curious. I wasn't aware you can do 3.27's but not much difference between those and 3.23's so no biggie there. Just trying to get as much info so you can get a more accurate answer let us know.
Old Oct 30, 2014 | 09:50 PM
Let just go with two cars have the same setup just one has a 3.73 gear set and the other has a 3.27 gear set. I'm thinking of going to the 3.27 gear as I have a bposted 5.3 with a 4k stall th400 swaped into my Mazda car. With the 3.73 Im turning the motor closer to the rev limiter then I want at the 1\4 mile. I was hoping that the 3.27 will drop the rpm without killing the 60 foot
