Rear Diff Choice
) and am looking for a good rearend. Only going to be in the 400-500 whp range, however I want to run a really strong and "drivable" rear. Either a MWC 9 with a wavetrac or a Strange S60 with a true trac. Ive heard a few bad things about true tracs in stick cars(as well as the detroit locker), but ive heard nothing bad about the wavetrac. An thoughts? If I were to get the MWC unit i would also probably go with the watts link, anyone have one installed or driven an f-body with one?Thanks
Matt
Matt
If it's the former, the Wavetrac is a better, higher bias diff for turning left and right.
) The wavetrac is the reason i want a 9, and the value of an MWC 9 with its snazzy torque arm is phenomenal. I was going to get a quick performance 9(with wavetrac) yet if you add the cost of a new torque arm and bracket to the Quick unit(around 500) its really close to being MWC price. Also, i get discounts on the rest of my rear suspension if i buy a rear (watts link or panhard, lca's).
As to answer your question dailydriver, I will rarely and potentially never take this car to a drag strip. It may see a track with... HOLY ****... TURNS(gasp) and will be daily/street driven. Will definetely be doing street pull though and car cruises/tours so shw will get beaten in a straight line as well. Somewhat high rpm launches as well Seen a couple videos on youtube(couple of f-bodies) where the watts link really tightens up the rear suspension and keeps the rear centered under the car. So in summary for my driving style/needs: turns:yes, performance:yes, drivability:yes, badassness: yes
The wavetrac is a smooth operating, pure power transferring beast. It feels like it should have been put there from the factory, its that smooth, yet it can hold up to 1000hp and probably more. Stranges S-trac should be a similar product but again i have no experience.
The truetrac is a posi unit that ive heard just doesn't handle the power very well and simply fails, as in the posi doesn't work and you have a peg leg rear. So in regards to the truetrac issue, it was more about them breaking/ not having positive traction capabilities after a few high rpm/high drivetrain shock launches.
Can you describe your issue a little more thouroughly I may be able to help...
Yeah i recommended an S60 to my friend (Juiced2002) he has an install thread on here, it was a cheaper alternative to a 9 or 12 bolt(we were both in high school, im now in college so money is still tight) which he got with the locker, which is where my locker "experience" comes from. I like the S60 platform yet really want the performance of the wavetrac (not offered in an S60(yet)).
Even though you don't plan on going to the strip, with your estimated power on DRs a upgraded rear is a good idea.
So that puts you at around 3500... for 500 dollars more (im at around 4000 with the options i want with an mwc unit) the lifetime warrenty the wavetrac is calling my name.
Just to clarify, I have no objections towards the S60 casting, ring gear strength etc. Its just the differential itself im worried about.
The backlash in a Locker causes manual trans shifting issues, backlash on my S60 is nil.
