Which drive shaft
Old Feb 6, 2015 | 04:47 PM
All Pontiac WS6's Avatar
Default Which drive shaft
When I bought my 1998 roller TA it was missing the drive shaft. I understand that I can use a factory one with my 4l80e. Does it matter if it comes out of a v6 car ?? I know I will need to change the yoke out. So which one, steel or aluminum and why ?? Thanks, David
Old Feb 6, 2015 | 08:12 PM
JakeFusion's Avatar
Super Hulk Smash
I'd just upgrade to a 3.5" aluminum or a 3" chromoly aftermarket piece. Then you can get exactly what you want and something pretty beefy.
I went with a 3.5" aluminum and it's a great piece from The Driveshaft Shop. PST also makes a great one.
I do have a 3" stock LS1 for sale if you need it. It's better than the 2.75" LT1 steel one.
Old Feb 9, 2015 | 05:09 PM
01ssreda4's Avatar
All stock shafts are junk. Buy a good built one and if budget is tight go with steel or chromoly.
Old Feb 14, 2015 | 11:45 AM
JRENIGAR's Avatar
v6 cars had 2 piece ds so they wont work period.
Old Feb 14, 2015 | 06:14 PM
dtroike's Avatar
I have a Strange 3" chromoly with 1350's and a 32 spline yoke for a 4l80e. 40" long from center to center of u-joints. Worked perfect with a 12 bolt. $225
Old Feb 14, 2015 | 07:41 PM
Right now I am running the stock rear end. Just wanted something to get it moving.
