loose yoke
Old May 3, 2015 | 10:21 PM
tricked94camaro's Avatar
Default loose yoke
the yoke going into the diff on my cousins 2000 ss is loose. could it just be the seal? would all I have to do is unbolt the yoke and pry the seal out and use a socket to tap a new one in? at least, that's how its done on heavy duty diesels..... it is leaking oil from there too so I know its bad....
Old May 4, 2015 | 07:23 PM
S10xGN's Avatar
Not good! If the nut holding the yoke is still tight, then the pinion bearings are gone. Either way, the R&P is prolly toast...
Old May 4, 2015 | 09:41 PM
it still drives good and strong except for a slight vibration at higher speeds and what seems to be a slight grinding when I lay off the gas....
Old May 5, 2015 | 07:14 PM
S10xGN's Avatar
Good luck with it. When it comes apart, have both hands on the wheel!
